how do i get this cable out?
Old Jan 30, 2004 | 09:58 PM
llvll4l2c91350's Avatar
this is the kickdown cable right?? how do i unhook it so i can drop the tranny?
Old Jan 30, 2004 | 10:14 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yep, that is the kick down cable and If I remember correctly from doing mine, just pull down on that lever and the cable is just hooked in there. Or have someone push the throttle to wide open and the disconnect it. The cable goes through a rubber boot into the transmission case. Oh yeah, there is also a bolt holding the cable to the case on top, it is visible in the picture.
The Trickster!!!!!!!!!
Old Jan 30, 2004 | 11:09 PM
ok thanks yea i was trying to unhook the lever and the thin metal rod instead of the cable itself.
Old Jan 31, 2004 | 02:42 PM
DigitalMonarch0's Avatar
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
Grrrrrrrrrrrrrrrrrrrrrrrrr
Bad, bad memories. That cable gave me more problems then I could have imagined.
Old Jan 31, 2004 | 03:18 PM
sillyiroc's Avatar
Car: 89 Iroc
Engine: 350 vortec TPI
Transmission: 95 T56
That is the Tv cable not a kickdown. You must unhook the cable at the TB and unbolt the 10mm bolt shown in the picture. Lift up on the cable wich will make it much more easy.
Old Jan 31, 2004 | 03:44 PM
Engine: 5.0L TPI
Axle/Gears: 3.08
You do not need to unhook the cable at the TB, it will come apart without even opening the hood. Just make sure you adjust it when you're done.
Do lift up on it though as it will give you more room to manuever it around.
Old Jan 31, 2004 | 09:37 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I know the feeling well, I had to change mine because the previous owner had kinked it real bad. In the process of pulling the old cable out, I acquired a vocabulary that would make even the saltiest sailor blush. Then I happened to spot the bolt and bracket that was holding the blasted thing to the back of the engine. After putting several 1/4" drive extensions together, I was finally able to get a socket on the bolt and loosened the bracket enough to pull the cable through. I forgot to mention that car was outside, it was cold out, had transmission fluid dripping on me, busted knuckles, rain started, and the wife sweetly asks " honey, can you go to the store for me".
The Trickster!!!!!!!!!!!!!
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
