Will Caprice transmission bolt up?
Old Jan 31, 2004 | 08:54 AM
bluebowtie67's Avatar
Car: 1984 Z28
Transmission: 700R4 w/shift kit
Might be doing an engine/trans swap in my 84 camaro z28. The drivetrain from the camaro will fit in the other vehicle.. However, not sure if the 86 caprice trans will fit in the camaro. They are both 700R-4's but I've heard that camaro bellhousings are different.. If this is so, will the engine/transmission combo fit in the camaro, or am I screwed until I can fine a camaro transmission? Well, gotta figure something out soon....
Thanks for any help..
Old Jan 31, 2004 | 10:05 AM
ede's Avatar
ede
it'll bolt up if both are SBCs or 90*v6s. the torque arm may give you a bit of a problem.
Old Jan 31, 2004 | 10:16 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes it will bolt to a V8.
You'll need to use the extension housing off of your existing Camaro transmission, in order to keep the torque arm mount.
Old Jan 31, 2004 | 11:24 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Like mentioned yep. A few things you may want to consider. If its a 4.3 caprice it's missing a few clutches but its not a big deal. The governer may be better but it may not so you might want to take a look and see if it has lighter springsif so use it. Since you need to remove the tail shaft housing make sure to swap speedo gears while its out of the car.
midge54
Dec 27, 2019 04:14 PM
Reddeath210
Oct 6, 2015 08:20 AM
camaro71633
Sep 1, 2015 10:24 AM
blackd-out z28
Aug 15, 2015 08:18 PM
