Gears, Gears, and more Gears?
Old Feb 3, 2004 | 03:26 AM
Maniac's RS's Avatar
Car: 92 Cherry Camaro RS
Alright i have been reading posts on gears and have found a lot of information but nothing that has answered my question.
Here's the specs on my car:
92 RS
305 tbi
Auto
Pretty much stock except for: MSD Ignition & Wires, K&N Airfilter, and soon-Catback Exhaust.
This car is a daily driver on the highway with weekend trips to the drag strip.
What gears should i go to in the rear?
I was thinking 3.42 or 3.73's.
I talked to a guy that is like just go 4.10's but i think that maybe a little drastic for my use.
I would like to liven her up a little and also put in posi.
Thx,
Chris
Old Feb 3, 2004 | 03:27 AM
Kandied91z's Avatar
4.10's are a bit much with an auto....however you have a different engine then i.
an good posi and a 3.73 works nicely.
Old Feb 3, 2004 | 05:07 AM
ede's Avatar
ede
lot would depend on what you're wanting to do with it
Old Feb 3, 2004 | 07:43 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You can't go wrong with a 3.42. Great for all around and highway use. If down the road you plan on a little higher reving combo a set of 3.73's will be nice. Like ede said, it really depends on what you want to do with the car.
Old Feb 3, 2004 | 08:51 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Given your current combo I would say go with 3.42s or 3.73s. The 3.73s will give you more punch, but the highway RPM will be higher, even with overdrive.
A higher stall converter would work really well with either of these ratios. Something in the 2,400 range with either combo could easily shave a second off your ET depending on what your current gear ratio is.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
