small chip on pinion tooth
ok i see a small chip in my pinion, on one tooth. the chip is in the valley where the tooth makes contact with the ring.
top of the pirion --head-- in the valley.
replace it? file it down??
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Re: small chip on pinion tooth
The " root " area ( Valley ) of the pinion tooth has the highest loading. Usually when a pinion tooth fails it will fail in this area.
Will eventually just shear off.
i called randys ring and pinion, described the chip....they said it would be ok....
who knows....i may run it, i may not....id rather NOT run it....
too bad there arent any places around here that specialize in it...id ask them...anyways heres a pic of where it is....
this isnt the actual pinion, its just a pic i grabbed off the web, and drew where the crack is
Car: 86\92 Mutant
Engine: 355CI 430HP
Ok...that's not in too bad of an area. Chip is at very end of pinion valley where loading is less. One thing though is important,
you stated in your second post:
Quote " this isnt the actual pinion, its just a pic i grabbed off the web, and drew where the crack is
Is it a crack or is it a chip? Important difference. If it's a crack forget about it. That tooth will fail.
If it's a chip, you can probably grind a radius where the chip is with a fine stone on a Rotary tool like a Dremel. That's what I would do. Being on the end like that, you can get at it. If it was in the middle of the root it would be much harder.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
