Speedo Question?
Old Feb 12, 2004 | 05:47 PM
firebird frenzy's Avatar
Speedo Question?
This is probably one of the dumbest questions you have ever heard but is there such a device that can turn a mechanical speddo setup into a electrial one.
Old Feb 12, 2004 | 08:20 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Speedo Question?
It is not a dumb question and yes there is. Check out the guys who have done the T-56 swap. Try a search under "T56 speedo question." There are a few ways to do this but it requires you to buy more than the tranny.
Old Feb 12, 2004 | 09:31 PM
STU86ZLT1's Avatar
Car: 1986 Z28
Engine: 1997 LT1
shifty, i was having that same problem too, i found a company called TERF.COM , that is in the process of making an adapter that will adapt a mechanical driven speedo connect to a 4L60E trans. the guy told me about 2-3 weeks till its done. hope this info helps.:rockon: Good Luck to all those LT1 swappers out there, time to spank some mustain ***!!!
Old Feb 12, 2004 | 10:00 PM
CorVM's Avatar
Car: '92 Pontiac Firebird
Engine: LO3 305ci.
http://www.skulte.com/T56.html Has info about the T-56 swap, and under Speedometer Calibration it has a link for a box that does just what you described.
Hope that helps,
-Corey
Eric2ndGen
Nov 5, 2015 01:51 PM
stickychinsac
Aug 31, 2015 06:06 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
redmaroz
Aug 16, 2015 11:40 PM
beachrodder
Aug 7, 2015 04:27 PM
