T56 bellhousing to L98?
Car: 1989 Firebird
Engine: Toilet Bowl Injection 305
Transmission: Autotragic
I've been told that the T56 bellhousing will not work with an L98. They said I'd need a custom piece to make it work. Any truth to this? I did a search and couldn't find anything directly addressing this issue.
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Originally posted by 914Mula
93'-97' LT1 t-56's will bolt on without any modifications as far as the bellhousing's go.
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Whoever told you that was lying or didn't know what they were talking about. The LT1 bellhousing bolts right up with absolutely no modifications.
The LS1 uses a different bolt pattern and isn't a bolt up swap. It would have to be modified. You could also use the new McLeod modular bellhousing to make that work.
Car: `86 SS / `87 SS
I used to take One a day vitamins. Now I just correct you once a day.
I did know that the input shaft was a different length.
That the LS1 had a different bolt pattern must have been a rumor, though I could swear that I read it somewhere.
You really should take a lot more than one vitamin a day. There just isn't enough of each nutrient in one of those "one a day" pills. I take 12 pills every morning, including a good antioxidant package. Really makes you feel well : )
