Rebuilding a 9-bolt
Old Feb 17, 2004 | 12:13 PM
carfixxer's Avatar
Car: 87 GN & 87 T
Engine: 3.8 V6
Transmission: 200r4
Rebuilding a 9-bolt
Are there any kits available to rebuild these? or all the individual parts needed from GM? I called Randy's Ring and Pinion and all they had for this was a whole posi unit at $1200.
Any replies are appreciated
Old Feb 17, 2004 | 03:44 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
If the rear is already apart you can take the numbers off the bearings and races and get replacements from NAPA or other parts stores. The make of the bearing isn't important. They use a universal numbering system. I highly recommend Timken bearings and races if possible.
I don't know a lot about the 9 bolts, but from what I hear parts are hard to get for these rears.
Old Feb 17, 2004 | 04:03 PM
91FireChicken's Avatar
Car: 91 Firebird
Transmission: A4
www.9bolt.com
Old Feb 18, 2004 | 06:39 PM
hot69z's Avatar
Car: 1982 Z/28 H.O.
Engine: 355
Transmission: t-5
http://www.precisiongear.com/
They can get you rebuild kits exept for the posi unit
Old Feb 18, 2004 | 09:40 PM
carfixxer's Avatar
Car: 87 GN & 87 T
Engine: 3.8 V6
Transmission: 200r4
Thanks I am going to make a few calls...
Well heres what I found out so far, Precision, Randy's & GM do not have rebuild kits or individual parts so it looks like a whole posi unit is required. GM wanted $1500 and Randys $1200 looks like my best option is to get a junked 4th gen rear end.
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
