Suggestions for removing the fluid fill plug on T-5
Old Feb 20, 2004 | 12:32 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
It looks like the plug is for a 3/8 drive breaker bar or ratchet but mine was hard to turn and the ratchet slipped out and barely stripped the fitting. I might have another chance to break it loose before it is totally stripped question is what to use to break it loose. Penetrating oil? WD40? Need help cause I know I leaked out half a quart of Dextron II and want to replace it. Also where else would I be able to put in fluid, under the shifter? Thanks.
Old Feb 20, 2004 | 12:46 PM
ede's Avatar
ede
might want to dig around in the recess and make sure it's clean so your breaker bar fits fully into the hole.
Old Feb 21, 2004 | 12:26 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
I hope the one you're messing with is the upper one on the passenger side...
All the ones I've seen have a square head on them that you can fit a wrench onto, although the later ones could be different.
maroe624
Apr 16, 2017 08:29 AM
backtothe80s
Sep 5, 2015 12:39 AM
92camaroJoe
Aug 13, 2015 06:07 AM
3rdgenparts
Aug 8, 2015 07:09 PM
Leggman1
Aug 6, 2015 04:15 AM
