driveshaft leaking
Old Feb 21, 2004 | 11:55 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
driveshaft leaking
tranny fluid comming from the driveshaft on 5speed? lost a lot of fluid.
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Rear tranny seal is prob seen better days. Replace it.
Old Feb 22, 2004 | 12:28 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Exactly. Inspect the tailshaft bushing while you're there too. Also, make sure the yoke doesn't have any wear spots in it from the seal. If it does replace it with a new or good used yoke, or it will just start leaking again shortly after you replace the seal.
Old Feb 22, 2004 | 12:53 AM
Engine: 5.8
how do i chang the rear seal
Old Feb 22, 2004 | 12:58 AM
Engine: 383, L69
Pull old one out, with seal puller or screwdriver see what works for you, then place the new one needs to be hit into place, make sure you hit it in evenly, via a 2x4.
Old Feb 22, 2004 | 01:02 AM
Engine: 5.8
ok
Old Feb 22, 2004 | 06:12 AM
ede's Avatar
ede
might want to look at the bushing inside the tail shaft to see if it's worn and needs replaced also
RS Reaper
Oct 17, 2018 07:52 PM
Reid Fleming
Oct 10, 2015 09:56 PM
loud91rs
Oct 5, 2015 10:05 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
