ET gains from 3.73
Old Feb 23, 2004 | 11:19 AM
WinnipegGTA's Avatar
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
ET gains from 3.73
Straight stock GTA with RamAir mod and Nitto DRs..would there be any reduction in E.T changing out from 3.23s to 3.73s. Im aware im going to loose topend. i can deal with that later.
Old Feb 23, 2004 | 01:17 PM
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
Nobody has ever swapped from 3.23 to 3.73 and noticed a gain?
Old Feb 23, 2004 | 02:06 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Im pretty sure it won't be a pretty steep gain. I remember reading one site that had done the ls1 swap and he upgraded to 3.73's and got a tiny but noticable gain. Its when you switch from 273's or so you can see a noticable gain I believe. You will get a gain none the less.
Old Feb 23, 2004 | 03:31 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
ive seen some people go from a 2.73 to a 3.73 and drop a full second off of their ET no 3.23 is exactly in the middle of the two so i would venture a guess of .5 quicker ET
Old Feb 23, 2004 | 03:41 PM
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
Well i doubt i will see a half second ET drop but would any take a stab at .2 or .3 off my ET?
Old Feb 25, 2004 | 12:46 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Cam...it depends on lots of variables like tire size and the engines power curve. I would imagine that stock TPI cars don't improve a whole lot as they peak quite low in RPM. You don't want to be out of your power band when you are at the top end of the track.
Old Feb 25, 2004 | 05:51 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
pretty soon im swapping my 3.08 to 3.73
antman89iroc
36
Jan 31, 2016 08:42 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
JSDaddy189
Sep 26, 2015 03:50 PM
whyt86roc
Sep 10, 2015 10:03 PM
