2002 10 bolt NEED Help Assembling
Car: 1990 Firebird Formula
I bought a low mileage `02 10 bolt out of a trans am from a guy with the c clips burried in the case and the axles loose.
I've got the axles in, the c-clips installed, and the block in.. I know the torque specs for the small bolt that holds the block in the center of the diff (25 ft lbs)...but I don't know the torque specs for the "bearing caps" on both sides of the diff... what I mean when I say bearing caps is the metal "caps" or covers that go over the bearing at each side of the case.. They where also loose when I got the axle.
If I need to borrow a digital camera to show you guys let me know.. I am very close to having this thing assembled and I am just be held up by these last 4 bolts!
Thanks guys
Thanks guys
Hotrodboba400
Dec 10, 2019 07:07 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Night rider327
Sep 2, 2015 04:17 AM
