Is a 1988 T5 World Class?
Old Feb 25, 2004 | 12:40 PM
5.8L Camaro's Avatar
Car: 1988 Camaro
Engine: 350 V-Eight
Is a 1988 T5 a World Class or NonWC? I did a search, read alot, and have heard they are and they arn't. Someone please give me the correct answer.
Old Feb 25, 2004 | 12:43 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it's out of one of these cars, yes, it's the 2nd design.
Old Feb 26, 2004 | 08:59 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
the one in my 88 formula looks like it's a non word class deally.. has the plug in the front.
at least that's what i remember being the difference externally the freezeplug style cup plug
Old Feb 26, 2004 | 09:34 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Here's how you identify them. You can see the part in question with the trans in the car. Top pic is 1st design, bottom is 2nd design.
Old Feb 27, 2004 | 08:47 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
What year did they go to the WC?
John
Old Feb 27, 2004 | 08:51 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
87
Old Feb 27, 2004 | 03:41 PM
Car: 1988 Camaro
Engine: 350 V-Eight
Ok, its a world class.
Old Feb 29, 2004 | 09:50 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
so im guessing my 88 GTA has a WC in it?
Old Feb 29, 2004 | 09:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Maybe.... look
It's like "do I have a posi?" We can all guess, look up codes, talk about what it should have, what year or motor option or whatever, etc.; but nothing is quite as certain as looking.
Old Mar 1, 2004 | 12:46 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Actually, 1988 models were the first ones to get the WCT5. 1987 models have the regular T5.
Old Mar 2, 2004 | 09:16 AM
JBert's Avatar
Car: Looking
So then whats the diff- Looked at mine last night- just says Borg Warner on it
Old Mar 2, 2004 | 10:11 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I have both the NWC and WC, both say Borg Warner on them. One way to know is to get the numbers off the tag attached to the rear tailshaft housing bolts and look it up on gearzone.net.
I've also noticed my NWC has cast in the side of the casing "Basic 1", and the WC says "Basic 1A"....
Pretty much, if you can verify it's the original trans, all '88 - 92's got the WC trans.
Old Mar 2, 2004 | 10:38 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Look at the pics.
You see that round thing, not the big rusty one with bolts in it at the top right of each pic, but the smaller one near the center of each? That's how you tell just by looking.
Old Mar 2, 2004 | 12:10 PM
Confuzed1's Avatar
Car: 83Z28 HO
Originally posted by RB83L69
Look at the pics.
Yeah, right...I know what you mean and I'm not disagreeing with you....
If you've looked closely enough to recognize that difference, then you may want to look at another difference. the Basic1 or 1A on the side of the casing. You can see that also - just by looking.
Old Jan 27, 2014 | 01:06 AM
british bomber's Avatar
Re: Is a 1988 T5 World Class?
what if you have the case in the bottom picture but with the plug from the top picture does that make a difference?
Old Jan 27, 2014 | 06:39 AM
There's no "plug" in those pics up there... only the clutch gear bearing retainer and the front countergear bearing ... ????
If it has the bearing that looks like an upside down freeze plug, with an absolutely flat shiny surface except with the edges not "sharp", then it's a 1st design unit. If the bearing is dull and sort of greenish-gray with the center dimpled in such that it looks like there's a "step" about 3/16" wide all the way around and the edge is "sharp", it's 2nd design. The two designs are so profoundly different because of the 2 styles of bearings used, that there is no possibility of the one type of bearing being used in the other model of transmission. No further "identification" is necessary.
player 88
17
Jan 31, 2010 04:50 PM
CC
Aug 29, 2009 10:24 PM
wp4
Jul 13, 2007 11:02 PM
Chevyguy1984
Canadian Region
Apr 9, 2006 02:41 PM
