World class T5, SBC parts and TPI EFI set up
Old Jan 20, 2008 | 02:57 PM
player 88's Avatar
Engine: 360 .060 over TPI
SOLD MY CAMARO RACE CAR AND I AM CLEANING OUT THE GARAGE!!!!!!!!!!
World class T5 from 1991 Camaro 305 V8, car had approx 100K km. onit. Opened trans and inspected it. It had new synchros installed as some time. very good shape. $450 with factory shifter.
OEM used aluminum bell housing, form the above trans, with slave cylinder, heat shield, and release fork. $75
Steel drive shaft form above car $30
Lakewood #15020 used scatter shield bell housing for above trans or T10 with bracket for hydraulic slave cylinder for 1983-1993 Camaro/Firebird F- bodies with fork $250
I have BARE 350 small Chevy bolt 2 bolt main. Ready to be assembled bored .030 over ARP main studs, 2 piece rear main seal. fresh from the machine shop , hot tanked painted and new freeze pugs. $400 obo
Aluminum Chevy 85/86 Corvette heads. 163 CC intake ports, 58 CC chambers. casting number 14101128 approx 60-80 K on them. $300
Eagle cast steel 2-pice rearm ain seal 350 CHEVY crank NEW IN BOX, $175
Factory GM 2 piece rear main seal, FORGED steel crank STD/STD polished $200
Keith Black pistons 350 Small block Hyperutectic silv-o-lite +.030, -17 dish. Will give approx 9:1 compression ration with the above heads. Has factory rods on them with ARP bolts. Balanced Assembly has approx. 20k miles on them $150
set of re-manufactured 350 rods, combination of X and Pink rods, ARP bolts, balanced and ready to go low hours, $60
MT SBC aluminum valve covers$40
MOROSO valve cover, were gold, but are now black $40
HV oil pump, used low hours $20
misc Gaskets $50 includes 2 sets of head gaskets.
Clevite 77 main and rod bearings STD, MS-909 P and CB-663 P
$120 NEW IN BOXES
Clevite 77 main and rod bearings 10/10 MS 909 H and CB-633 H
Ran for approx 20 minutes, to break in motor. $80
Federal Mogul rod and main bearings STD 4663M and 2555CP $60 NEW in boxes
Used camshaft hyd. flat tappet vFederal Mogul CS-186R 230* dur. .480" lift 109LSA $30
Fedearal Mogul rings .030+ $50 for above pistons. NEW in BOX
Cloyes HD timing chain SBC for NON roller blocks $50
Mr gasket front pulley bolt $10 NEW in package
COMPLETE TPI EFI set up form 1988 Players series/ Firehawk MANUAL 5 speed Camaro.
includes computer, chips, harness, Accel 24# injectors, Jet adjustable fuel pressure regulator, MSD coil, distributor. , MAF air boxes $400
call me for a package deal!!
I can do an assembled short block for $900
Steve
cell 705-718-3483
Old Jan 20, 2008 | 03:22 PM
flyboy367's Avatar
Car: 02 redfire gtp coupe
Engine: 3.8 modded and supercharged
Transmission: 4t65-ehd
Re: World class T5, SBC parts and TPI EFI set up
interested in the heads. please email me some pics. is that 300 with or without shipping? are they complete with valves/springs?
thanks
Don
flyboy367@aol.com
also were they tpi or lt1 thanks
Old Feb 19, 2008 | 07:42 PM
player 88's Avatar
Re: SBC parts and TPI EFI set up
I have BARE 350 small Chevy bolt 2 bolt main. Ready to be assembled bored .030 over ARP main studs, 2 piece rear main seal. fresh from the machine shop , hot tanked painted and new freeze pugs. $300 obo
Eagle cast steel 2-piece rear main seal 350 CHEVY crank NEW IN BOX, $150
$120 NEW IN BOXES
COMPLETE TPI EFI set up form 1988 Players series/ Firehawk race car MANUAL 5 speed Camaro chip set
Steve
cell 705-718-3483
heads are from TPI , the lT1 didn;t come out until the early 90s
Old Feb 20, 2008 | 11:37 AM
digitalrebel's Avatar
Car: 90 IROC Z
Engine: 350 60 over
Transmission: t5 and 700r4
Axle/Gears: 3.08
still have the oem bellhousing
Old Feb 23, 2008 | 10:52 AM
player 88's Avatar
SBC Block, lakewood bell housing,Clevite 77 bearings and TPI EFI set up NEED GONE
$120 NEW IN BOXES
Used camshaft hyd. flat tappet Federal Mogul CS-186R 230* dur. .480" lift 109LSA $30
Cloyes HD timing chain SBC for NON roller blocks $40
Serpentine belt set up with water pump need tensioner and alternator, $150
Steve
cell 705-718-3483
Attached Thumbnails World class T5, SBC parts and TPI EFI set up-serpentine.jpg   World class T5, SBC parts and TPI EFI set up-water-pump-rev-rotation.jpg   World class T5, SBC parts and TPI EFI set up-mor-1.jpg
Old Feb 23, 2008 | 10:56 AM
player 88's Avatar
Lakewood scatter shield for F body with hydraulic clutch. good shape, with fork.
dual bolt pattern- OEM T-5 tilted and a straight up T10
Attached Thumbnails World class T5, SBC parts and TPI EFI set up-lakewood-scatter-shield.jpg
Old Feb 23, 2008 | 06:55 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
how much for the lakewood b/h shipped to marysville,ca 95901? thanks
Old Feb 25, 2008 | 03:52 PM
pontiac888's Avatar
Want a title? Post!
Car: 1988 GTA
Engine: l98
PM sent
Old Apr 6, 2008 | 11:51 AM
JR Performance's Avatar
Car: 89 Iroc-Z
do you still have the heads?
Old Apr 6, 2008 | 07:49 PM
player 88's Avatar
Sorry heads are sold,
The only thing I have left are the engine bearings,
thanks
Steve
Old Jun 4, 2008 | 08:57 PM
Screamin82 Z28's Avatar
Car: 82 Z28
Engine: 383 SBC
Axle/Gears: 3.50 9 inch
Would you happen to know where I could get a setup like this anywhere w/o shelling out serious cash?? Assuming yours is gone.
Old Jun 4, 2008 | 09:19 PM
lopezisgod's Avatar
Car: 86 iroc-z, 78 z28, 91 z28
Engine: 355-carb, 350-carb, 350-TPI
Transmission: 5speed, at, 5 speed
Axle/Gears: 3.42, 3.42-stock, 3.42-1LE
willing to ship the world class t-5?
to 18078 in the states..
pm if possible..
Old Jun 8, 2008 | 04:07 AM
J$Money's Avatar
Car: 1980 Chevy Stepside
Engine: 5.7L 350
Transmission: TH350
Axle/Gears: 3.73 L-Slip
do you still have the tpi set up, if so how much minus the coil and distributor
Old Jan 31, 2010 | 02:50 PM
TDean's Avatar
Want a title? Post!
Car: 83 Z28
Engine: 355 sbc
Transmission: turbo 350 / 4000 stall
Axle/Gears: 373 posi
very interested in the lakewood bellhousing send me an e-mail 3tdean@rogers.com. if you still have it I will come and get it
Old Jan 31, 2010 | 03:10 PM
TDean's Avatar
Want a title? Post!
Car: 83 Z28
Engine: 355 sbc
I will take the lakewood bellhousing if you still have it i am in whitby ontario so i will pick it up send me an email 3tdean@rogers.com
Old Jan 31, 2010 | 03:24 PM
bonesbrakr's Avatar
Idiot last post date was a year and a half ago.... try looking at the dates and if its a old post then PM him.....
Old Jan 31, 2010 | 03:27 PM
TDean's Avatar
Want a title? Post!
Car: 83 Z28
Engine: 355 sbc
and what does pm him mean
Old Jan 31, 2010 | 04:50 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
send a private message.... I however will not call you an idiot ;-)
PurelyPMD
May 5, 2016 04:57 PM
Damon
Sep 26, 2015 04:29 PM
webeeZ28
Sep 14, 2015 12:00 PM
scottmoyer
Sep 7, 2015 07:06 PM
jtwoods4
Sep 3, 2015 05:39 PM
