How many shifts do you go through when at the track?
Old Feb 25, 2004 | 02:22 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Just wondering. Post your the redline or what RPM you shift at, rear gears, tranny and rpm through the end traps. I am just trying to figure if my gears are optimal with my tranny.
Heres mine:
-6000 RPM redline
-3.42 rear gears
-In the 700R4 I would go through 3 gears and barely get into 3rd and cross the traps pullin' like 4000 rpm.
-With the T-5 swap I go through 3 gears. I am crossing the traps in 3rd at 5800 rpm.
Does anyone have a T-5 and go through all 4 speeds at the track?Would it do it with 3.73's, 4.10's
Old Feb 26, 2004 | 05:57 AM
Mandangelo's Avatar
Car: 89 IROC
Engine: 350 Carbed
Transmission: WC T5
With my Wc t5 i go thru the traps in 3rd @ 6500 @ 106 mph's.
I have 3.08's in the rear <I think>
Old Feb 26, 2004 | 09:08 AM
92camaro's Avatar
In my mustang I go through the traps in the 1/4 at about 175mph in 5th gear at 9000 rpm or so. But a buddy of mine has a camaro with a turbo 400 and is in third gear about 5000 rpm in the 1/8 @ 94mph. But he has 4.56 gears and only turns the motor about 6200. With your car with 4.10 gears you would need to pull 4 gear for the 1/4 mile.
Old Feb 26, 2004 | 09:39 AM
GASGZLR's Avatar
Maybe it's cause I peel first too much
according to Desktop drag is should pull all 4 gears and go through the traps at like 4000 in 4th. I did spin a lot at the track and my motor vapor locked a little off the line then kicked back on, so maybe that's why I only redlined 3rd and didn't go into 4th.
Old Feb 26, 2004 | 01:23 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
I'm shifting 3 times with a T5, and crossing the line at about 4500 in fourth. I have a 3.42 rear gear, and 26-inch tall tires (235/60R15 to be specific). This is yielding 98-ish mph. The LG4 has about 240,000 miles, so I usually shift at about 5200-5300 - according the the factory tach.
Old Feb 27, 2004 | 11:17 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I would trap at 109 and w/ 3.42's I would be around 5200 in 4th.
Old Feb 28, 2004 | 06:50 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I use three...go thru the lights @ 7100 rpm`s, 26 inch tires 4.10`s 3000 9 inch stall(700r4)
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
Numbah-1
Oct 2, 2015 08:27 AM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
