Will this rear end gear work?
Old Feb 26, 2004 | 08:21 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I found this auction on ebay for a rear end gear. Im not to keen on rear ends. Here's the link, any info that will help will be greatly appreciated.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33731
Old Feb 26, 2004 | 08:45 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Depends on what your present rear axle is, which is in most case for RS is 2:73 Auto with a 2-series carrier. In reply NO!
Old Feb 27, 2004 | 09:58 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
If that one wont work then what do i need to look for that will work? How about this one?
Old Feb 27, 2004 | 11:46 AM
DJP87Z28's Avatar
Again NO....Read 3-series carrier. Just check what gears your car has now.
Old Feb 28, 2004 | 08:36 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Say del91, why don't you buy the zexel differential from www.SLPonline.com and put in a three series gear that way? That is what I am having done right now. I am paying to have that headache done $175.00. Seems like a good deal to me.
Old Feb 28, 2004 | 10:01 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Ok well will those gears in that auction work with this posi unit?
It says that it is a 3 series, but again i dont know much about it.
http://www.slponline.com/view_produc...TNUMBER=64501T
Old Feb 29, 2004 | 08:01 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Yep! That is the one. You will need a rear end rebuild kit or equivalent. I got one from summit for the entire rear end and it cost me $117.95. There are cheaper ones out there though. It gave me all new bearings, shims, gasket, etc.
Old Feb 29, 2004 | 09:09 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
So when i but a ring and pinion for that unit i need to find one that is 3 series and for 7.5 10 bolt? Any thing else i need to look for?
Old Feb 29, 2004 | 12:22 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Since the posi is a 3 series you need a 3 series gear, I think the cut off was 3.08 and lower were 2 series, 3.23 and higher were 3 series. Someone correct that if I'm wrong as I cant remember right now. You can use a 3 series gear on a 2 series posi, but you must buy a ring gear spacer. I bought one a couple years back sinceI had a 2 series posi and was installing 3.42 gears. The spacer was $65 from some company in Las Vegas that I cant sem to remember right now. Also, you'll need to know what year the posi is from so you can make sure the axle splines match up to what you have in your car. Others will have to jump in for the year/spline info as I'm not familiar with that.
Old Mar 1, 2004 | 04:58 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
I believe it is 88 and up has 28 spline axles. 87 and older have 26 spline axles. Also, don't be alarmed if you see 7.625 or 7.5 on your gears.
Old Mar 1, 2004 | 05:35 AM
DJP87Z28's Avatar
1989 was the changeover year to the 28 spline axle shafts. However; a good number of early and RS models still recevied the 26 splines ones until the inventory run out in 89 . If there is a question on what you have on 1989 car, you need to check the spline count.
hectre13
Dec 11, 2023 08:14 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
