will 1995 camaro rearend fit my 82
Old Mar 1, 2004 | 08:11 PM
lukerene's Avatar
Car: 1982 t top,,z/28,
Engine: 409ci vortec
Transmission: all steel t700r4,1300 stall yahooooooooooo
reason being its got bigger brakes,,and itsa 3.42 possi,,
the car still has the complete rearend in it its a 1995 z/28 rag top,,
also will the front brakes fit my car,, without welding and cutting,, and making parts for the next 2 weeks,,i am in australia so its a bit hard ordering adapters from the U,S,A
Old Mar 1, 2004 | 08:14 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Yes the rearend will bolt up fine but if you use thirdgen rims they will stick out two inches on each side. I think you may also need to mess with the emergency brake cable. I think its time to make the 4th gen rear end a sticky. Seems like its coming up everyday.
Old Mar 1, 2004 | 11:12 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You will need to modify the e-brake cable and run 4th gen wheels or wheels that meet those specs. You are also going to have to fidle with the brake lines bit. The rear will bolt in but is 4 inches wider (2 per side) and will make a horrendous skate board effect with the stock wheels.
Old Mar 1, 2004 | 11:17 PM
lukerene's Avatar
ok i will forget it and buy a ford 9 inch
Old Mar 1, 2004 | 11:52 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
for YOUR money, you'd be better off with a 9 inch. import on a rear end is gonna be killer, so you should spend it on a good one. if you were in the US, i'd say go for the 4th gen. you're mnot, so don't. good luck.
Old Mar 2, 2004 | 12:19 AM
lukerene's Avatar
yep i hear ya ,, 9 inch yes
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
matthew911
Aug 12, 2015 09:38 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
