Urgent Help Needed!!!!!@
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
how am i suppose to get the c clips on with the slp posi??? help as i am in the middle of this project.
Car: 91 RS
Engine: 305 Tbi (L03)
Im not familiar with the slp posi but cant you see the spider gears. Maybe not the way it is but if you but the trans in neutral and spin the driveshaft theres got to be a point where you can see the spider gears in the middle. Then just push the axels in and pop in the c clips.
Car: `86 SS / `87 SS
Re: Urgent Help Needed!!!!!@
Re: Re: Urgent Help Needed!!!!!@
Originally posted by jmd
remove the bolt holding the paddle in the middle. Remove the paddle. Slide axles inwards, set a clip, push axle out. repeat on other side. Install paddle (must be tapped in with a hammer if you have > 3.73 gears.) Install paddle bolt.
Zachattack0925
Aug 12, 2015 09:52 PM
