.500 Boost Valve ?
Old Mar 5, 2004 | 08:18 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
.500 Boost Valve ?
Whats a Boost Valve? Whats the difference in a .500 Boost Valve and any others?
Old Mar 6, 2004 | 01:28 AM
HPP4mula350's Avatar
The .500 boost valve is a transmission mod that lets you hit OD at WOT. Lots of fun!!!!!
Old Mar 6, 2004 | 09:07 AM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Whats involved in installing it myself? Whats the difference in a .500 boost vlave and another size like .420 boost vlave?
Old Mar 6, 2004 | 11:47 AM
i had mine put in while i had the trans rebuilt, but i believe it is fairly simple, going into the throttle valve on the trans. The .500 boost valve is bigger than the .420, requiring more fluid pressure for the trans to downshift. It does affect the downshift points slightly, but once you get used to it, its no big deal, especially with lower gears.
Old Mar 7, 2004 | 03:41 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
The .500 boost valve will not let you hit 4th at WOT. The bigger boost valve increases transmission line pressure which firms up shifts.
Old Mar 7, 2004 | 05:58 PM
jonarotz's Avatar
Car: 91 Z28
Plant Protection is right it has nothing to do with WOT 4th gear. I think HPP4mula350 is thinking of the valve that goes in the valve body. the .500 boost vavle installs in the pump assembly.
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
sandman92084
Sep 12, 2015 10:27 PM
Doobie52
Sep 11, 2015 06:19 PM
tgp1990
Sep 4, 2015 06:24 AM
