Rebuilding rearend?
Old Mar 8, 2004 | 12:31 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Rebuilding rearend?
Hey guys, im about to pull the rear end from my 83 firebird to swap to my new 88 gta project car. The rear has 157,000 original miles on it, so it could probably use some freshening up. I assume I should replace the bearings and gasket, but what else do I need to do? Will I need any special tools for anything? I have never rebuilt a rear end before.
Old Mar 8, 2004 | 04:45 AM
ede's Avatar
ede
posting on one board and posting on the correct board is usually enough to get a answer to your question.
Old Mar 8, 2004 | 12:56 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
To replace the bearings you will need a press. You can usually run the center piece, and the pinion to a shop w/ a press and get them to press off the old stuff and the new stuff on for fairly cheap. The one I went to did it for free. Check and look closely at the bearing races though when you replace the bearings. You don't wanna ruin new bearings w/ old crappy races. You have have to get a removal too from Autozone to pull the races out and put the new ones in.
Old Mar 8, 2004 | 01:52 PM
ede's Avatar
ede
i have a home made race removal tool it's a round piece of steel about a foot long
Old Mar 8, 2004 | 08:20 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Lol sorry, I didnt mean to post in the chassis forum. Then I just went ahead and posted in the right place
Old Mar 9, 2004 | 05:53 AM
ede's Avatar
ede
yeah lot of people get confused about that, sometimes the rear is a suspension piece and sometimes it's a driveline piece.
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
