took drive shaft off and 1 cap came off !!
Old Mar 10, 2004 | 11:42 AM
NEOMASTERZ28's Avatar
Car: 85 z28
when i took down th edrive shaft 1 of the caps was stuck on the joint that comes form the rear, all the beraings look fine, the plastic piece is broken that holds them what to do !
Old Mar 10, 2004 | 12:39 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
go to local parts store and pick up a new U-Joint for about $10-$15.
Old Mar 10, 2004 | 03:44 PM
Car: 85 z28
so its not use able ,or what ?
Old Mar 10, 2004 | 04:01 PM
92MaroRS's Avatar
it might be able to but id just go get a new one unless its a fairly new U-Joint.
Old Mar 10, 2004 | 07:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They always come off. There's nothing holding them on most of the time. The only kind that have something holding them on is when they have a metal link under the clips holding the cups together.
As long as all the rollers are still there, and the trunnion has no grooves from them, re-use it. Grease it if possible. Use one of those cone-shaped tips in your grease gun; leave one cap on; hold the one you leave on with pliers or something, so that its grease seal seals; dose the 3 with the gun; and pack the one you take off by hand.
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
Ozz1967
Aug 16, 2015 10:23 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
