t56 questions????
Old Mar 11, 2004 | 10:14 PM
ehacker01's Avatar
t56 questions????
ok now I am really confused. With the mcleod bellhousing you can use the lt1 or ls1 t56? do you still have to use the pull type slave with this or does this let you run your stock type setup? do you still need the lt1 flywheel? P.S. this will be on a 454 that has a seperate external balance plate so that I can use a internally balanced flywheel. also http://www.5speedtransmissions.com has an adapter for the t56 lt1/ls1 taht says you can use a t5 style bellhousing...how in the hell does that work?
Old Mar 15, 2004 | 01:44 AM
ehacker01's Avatar
ttt
19irocz85
Aug 26, 2015 07:54 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
