Major Problem with Tranny
Old Mar 14, 2004 | 07:44 PM
DrewRS's Avatar
Car: 1990 RS
Engine: 5.0L/ 305 LO3
Hey whats up guys. Well something very very bad has happened today. When I got out from work on my lunch break started up my 1990 Camaro 305 TBI the tranny would not go into reverse. So I had to first get it into drive....((either regular or overdrive)) then put it in reverse to get it to reverse. Does anyone know what could be wrong? THanks for the 411
Old Mar 14, 2004 | 08:47 PM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
check your fluid level if its ok then check your cable were it connect to the tranny some times the plastic clip breaks off causing some play that makes it hard to select the right gear.
hope this helps.
you can check out my simple site at
http://darcom.org
Old Mar 14, 2004 | 09:53 PM
DrewRS's Avatar
Car: 1990 RS
Thanks man. I checked the fluid the fluid was just fine.......now getting to those clips may be hard. I take it is all under the car? Well I dont have any ramps to put my car on up to check it just yet. Thanks for the help though. Also my dad found a bolt in the drive way we are not sure if it came out of the car our not. It is a pretty good size bolt that is black so im not sure
Old Mar 15, 2004 | 02:07 AM
DrewRS's Avatar
Car: 1990 RS
im hoping that is what is wrong with it. Tomorrow im taking it in to get checked on what is going on. Since I have to work like crazy this week and don't have time to do anything myself. Could there be anything else wrong with it you guys think?
someone972
Aug 30, 2015 12:52 AM
spaigo
Aug 21, 2015 07:46 PM
zeitghaist
Aug 18, 2015 07:33 AM
Zachattack0925
Aug 12, 2015 09:52 PM
hokis
Aug 9, 2015 03:57 PM
