28spline conversion Q's
Old Mar 13, 2004 | 10:38 PM
85camaro350's Avatar
Car: 1985 Camaro Z28
Engine: 350 carb
Transmission: TH-700-R4
I am getting a Zexel takeoff unit from slp and it sais i need 28 spline axles to fit my 85 Z. What is involved in this, Just put the axles in? or do i have to do anything to the rear to get the 28s to fit right....thanks
Old Mar 13, 2004 | 11:37 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
no mods necessary. i do believe there is a difference in disk to drum axles, but somebody here should know for sure
Old Mar 13, 2004 | 11:40 PM
Engine: 350 carb
thanks...but anyone else know for sure about the axles??? no offense, but i want to make 100% sure that when i buy these things i can throw em in......also, what is this about setting lash or whatever
Old Mar 14, 2004 | 12:03 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
http://www.sethirdgen.org/10bolt2.htm
Old Mar 14, 2004 | 06:29 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Don't have to do anything, just put them in.
Old Mar 20, 2004 | 03:45 PM
ChevyCamaro420's Avatar
Car: '86 Z28
Engine: LB9 (305 TPI)
Transmission: 700R4 w/kit
you can't replace a 26 spline axle wit ha 28 spline without changing the carrier to match the axle spline.
That's ede's response from my post... i was wondering the same thing, cuz that SLP take-off unit is lookin pretty nice. Check out the post.
My post: need some rear-end advice...
Old Mar 20, 2004 | 06:53 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Everyone that I have asked says the carrier doesn't matter as long as it is a stage 3 carrier. But I am 100% because I haven't done the mod, but I will be in the next couple of months.
Old Mar 20, 2004 | 11:12 PM
Car: '86 Z28
hmm... from what i've gathered u need to get a carrier to match the spline count, in addition to the gears. The carrier series depends on the gears.
3.23 and above gears need 3 series carrier, anything below need 2 series.
I'm not positive, but that was my understanding.
Old Mar 20, 2004 | 11:17 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
But you can have a series 3 carrier and 26 spline axles. Are there different series 3 carriers?
Old Mar 20, 2004 | 11:18 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, 26 spline and 28 spline.
Old Mar 20, 2004 | 11:33 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Now this really sucks. So I am going to have to replace pretty much the whole rearend in order to replace the differential with the one from SLP. That's going to cost more than a new 26 spline differential.
Old Mar 21, 2004 | 12:14 AM
Car: '86 Z28
yep im right there with u... the SLP unit was looking damn good, but i guess im just gonna stick with the 26-spline and get a new limited slip differential.
Old Mar 21, 2004 | 11:46 AM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
no no no no no.... stop talkin crazy. go to the junkyard, look for an 89-92 (correct me on the year if I'm wrong) and gank the axles like a hobo at the breadline. they'll fit right in, and you'll have a little better axles that fit the takeoff posi. or, you could just buy a whole damn 4th gen rear from f-body warehouse. PM me if you want to contact them. posi/disc rears with 3.23's or 3.42's go for $150 through them.
Old Mar 21, 2004 | 07:56 PM
Car: '86 Z28
Are u positive? Many of the people ive talked to say that they dont fit right in, and a lot say they do.
Has anyone here personally done the 26 to 28-spline axle swap? If so, please post! I dont want to waste my money by buying a 26 spline rear if i could have just as easily gotten a 28-spline.
Old Mar 21, 2004 | 08:40 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
I'll second that request.
Old Mar 21, 2004 | 09:38 PM
Car: 1982 Trans Am
Engine: 383 chevy
about 90% sure the axles will work. you could also ask around here, as there's bound to be someone who's DONE it. have you thought about a 4th gen rear swap?
Old Mar 21, 2004 | 11:46 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Okay, so if I replace the differential with the SLP Zexel-Torsen I do not have to replace the carrier, right? According to their website it all come together, the carrier and the differential. It does look like all I need is two new axles.
Old Mar 22, 2004 | 12:47 AM
Car: '86 Z28
PM'ed u about the 4th gen rear flyitlike... wouldnt I need new wheels though?
Old Mar 22, 2004 | 08:20 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The SLP taeoff is series 3, and uses 28 spline axles. If you havea series 3 rear (3.23 or higher) you just need 28 spline axles. NOTHING ELSE.
-- Joe
Old Mar 22, 2004 | 09:04 AM
Car: 1982 Trans Am
Engine: 383 chevy
carrier=differential. you can't get one without the other. so yeah, if you want the zex, get it, and two axles, and 3-series gears. (3.23's, 3.42's, etc.)
Old Mar 22, 2004 | 08:32 PM
Car: '86 Z28
That mighta been adding to my confusion... carrier = differential. gotcha.
I've got a lot to learn... lol
Old Mar 23, 2004 | 09:36 AM
Car: 1982 Trans Am
Engine: 383 chevy
man, I'll tell you this: just when you think you know more than most, you learn a LOT. last night, a girl taught me evrything i didn't know about nitrous.... and WHY forged is better than hyper. i just always knew forged was better, but never why. but i do now. learning is what hot rodding is all about, brutha.
Old Mar 24, 2004 | 08:25 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
I did it.
I got a new Gov-Loc of ebay for $50.00, it was a 28 spline unit. My 87 T/A had 26 spline axles. I bought a set of 28 spline alloy axles from Moser. They worked with the new 28 spline diff in the old 26 spline housing just fine, with no modifications to the old housing required.
Old Mar 24, 2004 | 03:27 PM
Car: '86 Z28
That's exactly what I wanted to hear... thanks my3rdgen!
Linson
Oct 24, 2025 02:00 PM
2012sergen11
Oct 13, 2015 07:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
