Oil Cooler Question?
Old Mar 14, 2004 | 10:40 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
Yeah, si i want yo bypass the radiator lines from teh tranny, can i jut hook up a oil coller straight to the tranny and not use the radiator, and if so, which lines are in and which lines arou out, on the tranny....
Old Mar 14, 2004 | 11:47 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
On a 700R4, the top line is the return line (the top one on the radiator) and the bottom line is the feed line)... Doesn't really matter if you are going to bypass the radiator cooler. If you were going to keep the radiator cooler, you'd want to have the bottom line from the trans go to the radiator (to help heat the fluid up in cold weather, etc), then the top line from the radiator go to the auxilliary cooler input, then from the cooler output to the top line back to the transmission (so it can cool it down best right before it sends it back to the transmission)... Hope that was coherent enough..
Old Mar 16, 2004 | 04:53 PM
383 rocket bird's Avatar
Mist transmission cooler manufacturers recommend keeping the factory in radiator cooler and plumbing yours in after it. -John
Old Mar 17, 2004 | 06:37 PM
Charged350's Avatar
Car: 87 IROC Z28
is it really necessary or what....
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
