automatic to manual
Old Mar 16, 2004 | 12:56 PM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
Transmission: 700r4 auto
automatic to manual
i have a 1990 Camaro rs v6 with an automatic transmission. Does anyone know wut model or wutever it is and which one i need to switch to, to go to a manual tranny? also wut parts am i goin to need to do this?
Old Mar 16, 2004 | 02:02 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
say WHAT? j/k
you need the pedals, master/slave cyl, shifter, bellhousing, new clutch set, rubber boot from floor to shifter, manual top plate and boot, shift ****, some 12ga primary wire to extend the clutch start switch, crossmember (if diffrent), manual trans TQ arm mount, and the VSS for the T5 you're using...
thats should be most of it, if not all
Old Mar 16, 2004 | 09:09 PM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
anywhere i can find sum instructions on doin this or sum pics or anything?
Old Mar 17, 2004 | 08:12 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
www.thirdgen.org click the tech articals section.
also, look up all the auto->T56 and V8 ones..... same concept, wiring, and work.... just the bolts are in a slightly diff place.... and get a book so you know how to do your clutch.
other then the pedals, shifter hole and master cyl, its identical to doing a clutch job
Falcon50
Aug 22, 2020 03:26 PM
Lbibb
May 5, 2016 12:00 AM
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
loud91rs
Oct 5, 2015 10:05 PM
