What are my rear options?
Old Mar 16, 2004 | 03:31 PM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
Im looking into getting a new rear for my camaro. I was looking into aftermarket ones but they are a little pricey and a lot more work would have to be done ( so says mosers tech guys ). SO i was wondering , would i be able to beef up a 4thgen rear to handle a new engine with 360hp and about 380 trq? or would i have to look into etting an aftermarket rear? I think moser is going to want about 2300 for their complete rear, but then they said my stock rear brakes wont work.... anyone know anythign about this?
Old Mar 17, 2004 | 05:18 AM
ede's Avatar
ede
instead of beefing up a 4th gen rear why not beef up the one you have, they're the same thing.
Old Mar 17, 2004 | 07:24 AM
Bandit5's Avatar
I went with a Moser 9", but then again, I want at least 500HP. If you are staying under 400HP the stock rear should be fine as long as it is built right.
Since you seem to be on a budget, I think the best route would be to get some better gears and a zextel torsen posi unit. Your car already has the 28 spline axels, so you should be fine there.
Old Mar 17, 2004 | 09:02 AM
OutLaw305's Avatar
well what actually is done to beef up the 10 bolt rear?
Cause not having to buy a whole new rear just brightend my day!
Old Mar 17, 2004 | 09:38 AM
ede's Avatar
ede
weld axle tubes to the center section, girddle and braces
Old Mar 17, 2004 | 10:08 AM
87LS's Avatar
Car: 87 Camaro LS
Engine: LG4
Transmission: T-5 World Class
Axle/Gears: 3.08 Open baby!!
You can make a 10 bolt hold 400 no prob
A friend of mine has an Auburn gear and Eaton Posi unit.
He used the Royal Purple Axle stuff and a girdle and has had no probs, and he beats the crap out of it!
He has about 475 horse
Just maintain your axle lube and it will hold no prob
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
RedLeader289
Jan 22, 2016 03:05 PM
draco
Oct 4, 2015 09:25 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
