Info on TH700R4
Old Mar 17, 2004 | 08:13 AM
FastBack's Avatar
Car: 91' Firebird Formula WS6
Transmission: TH700R4
Info on TH700R4
where can i get some info on my 700R4 tranny? just curious.
Old Mar 17, 2004 | 08:55 AM
MdFormula350's Avatar
well in stock form they suck
if u have an ok shifting tranny but want better performance heres we u should think about.
a decent sized tranny cooler, from like B&M
and then look into getting a transgo shift kit.
also a vette servo would be nice to have.
these things alone will add performance to the 700r4 and make it last longer.
they are a 4 speed tranny (last gear being overdrive)
in thirdgens they use a lock up converter, with a tv detent cable
https://www.thirdgen.org/techbb2/sho...0r4+gear+ratio
Old Mar 17, 2004 | 11:09 AM
FastBack's Avatar
i think a b&m shift kit would be a good idea, what about drilling out the valvebody when i do that to get a little more snap out of the shifting? i am definatly gonna invest in a trans-cooler, cause heat really kill those TH700R4 trannys. do the trans-coolers come in different sizes? what size should i get if they do? i believe those are remote mounted right? just checkin. thanks again
Old Mar 17, 2004 | 12:24 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
TCI makes a nice one. they come in 3 different sizes and one thin profile version. they look great and from what i hear, they perform well too. are you running a stock engine or mild performance or what? the TCI should support you up too 400 HP. thats what they claim anyways
Old Mar 18, 2004 | 07:52 AM
FastBack's Avatar
i'm running mild performance, some mods but not many, not quite pushing 400hp yet, soon, very soon i hope
Fanatic1074
Oct 3, 2022 05:57 AM
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
