91 rs driveshaft
Old Mar 18, 2004 | 07:23 PM
1fast91rs's Avatar
Car: 1991 RS
Engine: 305 LO3(TBI)
Transmission: TH-700R4
91 rs driveshaft
i removed my driveshaft and now i am ready to put it back in are there any special i have to do to it before i can put it back in?
Old Mar 19, 2004 | 08:40 AM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Just make sure the shaft that slides into the trans is clean and re-install. Make sure everything is tight.
Old Mar 19, 2004 | 09:00 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It may be a good time to replace the universal joints.
Old Mar 19, 2004 | 10:26 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Make sure the yokes are lined up in the same plane or else it will be off balance.
Old Mar 19, 2004 | 11:21 AM
1fast91rs's Avatar
Car: 1991 RS
the shafts that going to trans and rearend are a little rusty what should i do about that?
Old Mar 19, 2004 | 01:31 PM
TA5LiterHO's Avatar
How rusty? If it's just light surface rust you should be able to maybe spray some wd-40 on there and wipe it off. It's a pretty smooth surface. Whenever you are going to have something like a driveshaft or transmission out of a car for awhile it's a good idea to put some grease on the shafts because they rust very easily.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
topteam54
Oct 6, 2015 12:21 AM
loud91rs
Oct 5, 2015 10:05 PM
apie2546
Sep 20, 2015 01:03 PM
89newfun
Sep 16, 2015 09:28 AM
