Ring and Pinion for 89 GTA??? What do you Suggest?
Old Mar 21, 2004 | 01:47 PM
kingbabone's Avatar
I've got an 89 GTA and want to change the gear... What do you recommend? I hardly drive the car on the highway, would a 4.10 be ok??? Any information would be great...
Old Mar 21, 2004 | 07:55 PM
MdFormula350's Avatar
what engine and tranny and rear?
u should have a 9 bolt rear end and gears / posi are a bit costly. might be better and looking for a complete rear end with the gear u want.
for stock tpi u want to only go so high like 3.73's for example.
Old Mar 21, 2004 | 11:28 PM
qualls86ta's Avatar
Car: 1986 Pontiac Trans Am
Engine: Forged H/C LS1
Transmission: TH350
Axle/Gears: 10 bolt 4:10
if you're not on the highway much a 4.10 is good, but I personally like a 3.73, ecspecially if its an automatic
Old Mar 22, 2004 | 05:07 AM
ede's Avatar
ede
also what you gear you use depends on what you want to do with the car. with OD trans 4:10s wouldn't be bad
Old Mar 22, 2004 | 06:19 AM
Screamin'87GTA's Avatar
Car: Trans Am GTA
Transmission: Rebuilt 700r4 with stage 3
I have an 87 GTA. I have a 3.73 in the rear end of my car.. You would be surprised how much that helps out... 4.10 is not as good on gas as the 3.73.... then again we are driving thirdgens, so who is worried about gas mileage
64goatman
Sep 9, 2015 01:09 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
tgp1990
Sep 4, 2015 06:24 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
