aftermarket vs. GM t-56 differences??
Old Mar 22, 2004 | 12:07 PM
mike88form350's Avatar
Car: 88' Formula 350
Engine: 358 ci TPI
Transmission: Tremec T-56
looking at doing ls-1 swap. already have aftermarket tremec t-56 with the adapter plate to mount the trans to a t-5 bell. my question is this... are the input shafts the same length on the aftermarket and a 98-02 GM unit? or can i use this tranny with an ls-1??? any help would be greatly appreciated.
Old Mar 22, 2004 | 12:17 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Tail lengths are differen't, you'll need a re-worked driveshaft.
Old Mar 23, 2004 | 11:10 PM
85TransAm406's Avatar
Car: 1985 Trans Am
the aftermarket T56 won't bolt up to a ls1 t-56 bellhousing. You would have to run a ls1 bellhousing, and the aftermarket t56 uses a T5 style clutch setup, not the ls1 type (hydraulic TO bearing)
Jorlain
Oct 8, 2015 01:57 AM
BAMiller
Sep 14, 2015 06:38 PM
IROCtometal
Sep 9, 2015 10:01 AM
angel2794
Sep 8, 2015 06:22 PM
greenyone
Sep 2, 2015 03:39 PM
