Trouble code 24 after auto -> T5 swap
Old Mar 23, 2004 | 04:55 PM
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
My car is a 87 camaro v6 and for some reason Im getting code 24 from my car now that I completed my 700R4 ->T5 swap. Does anyone know what this code means? I looked it up and its the VSS sensor but I dont have a VSS on my car.
Do I need a computer from a manual tranny car?
or how would I fix this?
Also, for some reason the engine usually stays at like 2k or 1500 rpm for a bit and then creeps down slowly when i put the clutch in. On every car I ever drove that was a stick the rpm dropped down the instant you put the clutch in and let off the gas.
Any ideas how to fix this?
Old Mar 25, 2004 | 04:24 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
The RPM thing is prolly your computer thinking there is an auto still behind the motor.
The 8-ies cars do have speed buffers in the intrument cluster attached to the speedo for the cruise and ECM reference. I drove around my 89 with a cable speedo and it not hooked up and it gave me a 24 code too, also my car kind of ran crappy, I think it might have gone into "limp home mode". That may be why your rpm's are doing this as well.
gmoutdoorsman
Oct 3, 2015 11:42 PM
Luigytico09
Oct 1, 2015 08:46 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
dusterbd
Sep 29, 2015 08:40 AM
Lmancha96
Sep 25, 2015 08:11 PM
