t56 and skip shift
Old Mar 25, 2004 | 06:28 PM
Tricked-Out-Toy's Avatar
Car: 91 Z28
Engine: Lt1
Axle/Gears: 3.70 auburn pro 9"
t56 and skip shift
im doin the t56 swap into my 91 Z28 and was wondering if ill need the skip shift elim kit for it?? the engine is a 97 LT1. thanks
Old Mar 25, 2004 | 06:48 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
you dont techinally "need" to, you can muscle through the reverse lockout solenoid. But since youre running the LT1 and that engine harness and ECM, you might as well.
Cheers
Old Mar 25, 2004 | 07:22 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Cheers
that didnt make any sence..... CAGS has nothing to do with the reverse lockout.
Tricked-Out-Toy :
if the engine is a LT1, and you hook it all up like stock, then you COULD get the "eliminator kit"
BUT
1. the "kit" is nothing mroe then a plug and a resistor on it. you could buy a $0.10 resistor. (pack of 10 is 99 cents at radio shack... and they're raping you at that price.)
stick the resistor in the CAGS plug and thats it.
2. you need to edit the ECM anyway because of VATS... so you could just disable CAGS there.
if you have a regular SBC, you dont even have a way to plug CAGS in so you dont have to worry about it.
athough with a non LT1 setup, you do have to figure out a way to run the reverse lockout.
Old Mar 25, 2004 | 07:54 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
Tricked-Out-Toy :
BUT
you are absolutely correct
thanks man. i must be losing it.
what mrdude said is correct. i dont know why i wrote about reverse lockout.
but while we are being critical , sense is spelled incorrectly in your post
haha, just messin with ya
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
racereese
Oct 3, 2015 03:46 PM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
