look at this
Old Mar 25, 2004 | 06:34 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
look at this
couldn`t belive it when I saw it
Old Mar 25, 2004 | 06:47 PM
goofnrox's Avatar
Happens all the time (especialy if you're running 11's)
Had a buddy with a 4 cyl, Mustang that the whole friction disc came off the hub. Make it *slightly* difficult to shift.
Clutches tend to be suprisingly fragile, hence some of the more stringent safety requirements(blow proof bellhousing, tranny blanket ect) as you go fast at the strip. It looks like you got lucky it didn't blow thrugh your bellhousing!
Thanks for sharing the carnage though, always fun to look at
