Bolting up Bellhousing
Old Mar 26, 2004 | 07:59 PM
colonboy14's Avatar
Car: Trans Am
1 of the 6 bolts holding the T56 bellhousing to the block was really hard to get to, so I had to pry the socket in there. I got it tight, but it didn't reach 70 ft/lbs when it flew off and kinda twisted the head on the bolt. (the bolt is structurally fine, no worries about it breaking or anything) I am afraid that if I try to tighten it again, I may screw it up even more. Is the one bolt not quite up to torque going to be a problem?
Old Mar 27, 2004 | 04:58 AM
ede's Avatar
ede
most likely not, but i've never had a problem keeping a socket on the bolts. with the right tools you should be able to tighten it up. to tell the truth i use an impact and not a torque wrench to tighten them up with.
Old Mar 27, 2004 | 09:32 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it 's one of the top ones, reach down from above with a box-end wrench.
Those are 3/8"-16 bolts. There's no way they're supposed to be 70 ft-lbs. I'm surprised you haven't broken one off.
35-40 ft-lbs is plenty. That's the usuall amount for any 3/8"-16 hardware. If they needed 70 ft-lbs, they would have used larger hardware, for which a 70 ft-lb torque setting would be more appropriate.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
jtwoods4
Sep 3, 2015 05:39 PM
jtwoods4
Sep 3, 2015 10:19 AM
tonys91rs
Sep 2, 2015 07:07 PM
