Auto to t56 guestion on shift linkage
Old Mar 28, 2004 | 05:40 PM
FIREBIRD7777's Avatar
Here is my other guestion on what do i do with this cable that goes to the steering wheel ignition key. Do i have to take this out or can i just cut it off and leave it . Im kinda confussed on what to do.
Old Mar 28, 2004 | 07:40 PM
Trux's Avatar
Car: grand prix/84 z28
Engine: 4.6 Northstar
Transmission: t-56
umm....
that looks like your emergency brake cable. That should go threw your floor board by your transmission cable.
Old Mar 28, 2004 | 08:08 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
nope, that is the cable that connects to the ignition lock cylinder on automatic cars, and prevents the shifter from being moved when the key is in the lock position, it also prevents the key from being removed unless the shifter is in park, just leave it disconnected it should be fine, just disconnect that cable from the shifter, make sure that u can insert and remove the key in the lock position, then tuck it up under the dash, id do it that way
Old Mar 28, 2004 | 08:35 PM
Ok yeah thats what i thought, wasnt sure what everone else was doing, Im thinking of making it into a ANTI THEFT device, putting a end on the cable to where i can lock the ignition key and then hide it. I know this wont stop a professoinal theif but for newbies it will, besides i got a few tricks on the professional theifs , only way there going to steal my car is with a rollback and winch
Old Mar 28, 2004 | 08:36 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
good idea
Old Mar 29, 2004 | 07:07 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
wont stop anything.
they already bypass it when they goto start the car... the usual method for GMs is to bust the far left side of the steering column, and yank the lil gear out... at that point everything in the column works as if you turned the key.
a AMATEUR theif (the ones you have to worry about) can do it in about a min... or less.
F-body driver
Mar 6, 2023 11:44 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
TheTraut88
Sep 11, 2015 05:16 AM
jtwoods4
Sep 3, 2015 05:39 PM
tonys91rs
Sep 2, 2015 07:07 PM
