kickdown cable
Old Mar 30, 2004 | 08:17 AM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
kickdown cable
I have a TH350 tranny that I just installed a week ago. I'm rigging up the throttle linkage and and choke cable and kickdown cables, and i realize, I'm not sure how the kickdown cable is installed. how tight doeas it have to be? also, do you hook it up so that the cable is all the way in, so that when the carb pulls on it, it kicks down? or do i have it backwards?
Old Mar 31, 2004 | 12:20 AM
Car: 1982 Trans Am
Engine: 383 chevy
anybody?
Old Apr 5, 2004 | 08:36 AM
Charlesrlee's Avatar
Kickdown cable
Hey Fly,
Just spent the weekend playing with my kickdown cable I installed on my 400. If you adjust the cable all the way in then your tranny will kickdown when you don't want it to. Play it out a bit, test it and see where you like it to kickdown............
Old Apr 5, 2004 | 06:17 PM
Car: 1982 Trans Am
Engine: 383 chevy
thanks, man. my car will probably crank, get tuned, and test drive tomorrow. I'll see what happens and post then.
Old Apr 7, 2004 | 02:56 AM
kd5boc's Avatar
Car: 92 RS
the "proper" way is just like the 700r4's. Push the button, and slide the cable into the bracket, then make the carb/EFI go to WOT and it will click...should click and pull out to where it should be.
Also, when at WOT, TH350s will usually stay in gear until you let off a little, then shift....90-95% if I remember right. Most...but not all.
Tom
Old Apr 7, 2004 | 04:36 PM
Car: 1982 Trans Am
Engine: 383 chevy
what button? I have an edelbrock performer carb on an RPM intake. all i see is a hole where i think I'm supposed to hook up the kickdown... just not sure how to do it...
Old Apr 7, 2004 | 04:44 PM
DigitalMonarch0's Avatar
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
Slap me twice and call me a newbie... but is this the same thing as adjusting the "TV" cable on my TBI? When I installed my shift kit last summer, I lost the kick down in my transmission almost completely.
Is this something that might resolve the problem.
Old Apr 8, 2004 | 12:57 AM
Car: 1982 Trans Am
Engine: 383 chevy
hmmmmm..... I have no idea. I have no experience with the 700r4.
Old Apr 8, 2004 | 08:13 AM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
Transmission: Built 700R4
Probably will. The TV cable controls the fluid pressure in 700R4's which affects all functioning of the transmission.
Old Apr 8, 2004 | 08:27 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
At the carb end of the cable housing look for a plastic U shaped piece that lifts up or out. That will release the adjuster. Then hold the carb at WOT and pull back on the cable, push the U shaped piece back in to lock it.
RBob.
Old Apr 8, 2004 | 09:48 AM
Car: 1982 Trans Am
Engine: 383 chevy
sorry man.... no u-shaped piece. I think that the cable i have is a universal piece. someone in tech/ general engine suggested installing some kind of stud i can get at my auto store..... what about that?
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
