t5 ?
Old Mar 30, 2004 | 06:47 PM
harryo's Avatar
Car: 1989 chevy trk4x4,1994Z28
Engine: 307to400 (colector)
t5 ?
whats the difference between a wc t5 and a t5 also what years was the wc t5 in and the years the t5 was in? will a t5 from a v6 fit in a v8? iknow the bellhouseing will have to be changed.
Old Mar 31, 2004 | 01:36 PM
crnsuperduty's Avatar
Car: 88 sc. convert
Engine: 305 TBI
Transmission: Formerly 700-Now T5
WC is supposed to be a lot stronger. No Don't put a V6 tranny in a V8 car. It will not handle it. It's only a matter of time before it gives up.
Old Mar 31, 2004 | 09:41 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
ok my understanding is the t5 from the 6 cyl does not even bolt up to a v8 am i wrong?
Old Apr 1, 2004 | 11:44 PM
5speed4life's Avatar
Car: 83 Trans Am
Engine: 355 4 bolt main, One day it will run.
well, yes and no. The tranny will bolt right up to the v8 bell housing, but the splines are diffrent on the imput shaft. Just get a clutch disk for a v6, and you will be fine.
I found out that this is what someone did on my 85, but i was lucky that i was replacing the v6 tranny with a v8 tranny, and the clutch at the same time.
i didnt even realize they were diffrent untill i found the old clutch layin around and started to play with it, and my clutch alignment tool. go figure.
