race built 700r4
Old Apr 1, 2004 | 11:40 PM
proryder2's Avatar
Car: 73 chevy truck
Engine: 406 11.6 comp 2.02 heads
Transmission: stock th350
race built 700r4
i got a race built transmission from a guy off ebay. its supposed to hold 675 hp. i got it with a 2000 stall converter. well after a couple days of driving it conservitly i tried manualy shifting it to take the motor up more into the power band instead of stifting at 4500 i shifted it at 6000 like i used to with my old th 350. lemme tell you that first gear is out of hand. but anyway i go to shift into second after hold it to 6000 in first and as soon as i click up two second i hear the tires chirp and a really loud bang. then the engine acts as if its in neutrual. so i pulled over and checked if any of the gears worked. only reverse worked. so i had to get towed home. i drained the fluild and metal was everywhere. so now i have the th 350 back in and i was wonding if anyone have every had this problem also. any ideas what let loose? thanks
Old Apr 2, 2004 | 03:40 AM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Did it have a warranty? Which guy on ebay did you get it from?
Old Apr 3, 2004 | 02:16 AM
proryder2's Avatar
Car: 73 chevy truck
it has a 1 year warrenty. i called him and he said hes replece it as soon as he got the old one back. i got it from transrus. im really starting to think it was a junk yard rebuild with shift kit and not what he listed in the auction.
Old Apr 3, 2004 | 12:02 PM
caplt4's Avatar
Car: 92 Trans Am gta
Engine: 305 EFI
this reason why that happen it's because your tranny blow up, in a matter of speech, you rev up so high an switch gear, from first to second, in second gear the band applies an the drum stops spinning an is connectted to the reaction sun shell, which it has teeth an connects to the sun gear, the teet of the shell is the ones that break, which is one of the weakes part of the 700r4 an the 4l60e, which in gear an bans they are the same. hope this explains some.
Old Apr 3, 2004 | 12:51 PM
proryder2's Avatar
Car: 73 chevy truck
so do you think it was built right or can 700r4s not handle much horsepower even when built?
Old Apr 3, 2004 | 08:33 PM
caplt4's Avatar
Engine: 305 EFI
proryder2, if it was build right, it shouldn't brake, if they claim it's a race tranny, they should raplace the shell with the heavy duty one, should have etheir blue or red cluches, with a after market servos, an heavier spring on the accumulator, heavier spring on the pump for higher psi an heavier springs on the valleys, if it was done right it should not brake, an if this guy tell you it's warrenty ask him to send you another tranny, an a writing statement or specifications of what he has done to the tranny an what he replaced to make as what he calls "performance tranny" hope i'm not stepping on nobodies toes with this. let us know the out come an if you can when you get the spec poste it so we can see it.
Old Apr 3, 2004 | 09:46 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
www.700r4.com
read up on what they say there...
good tranny;s, have one in my friends formy...stage 3,and man it shifts perfect, not too hard, not too soft...
Old Apr 5, 2004 | 12:20 AM
proryder2's Avatar
Car: 73 chevy truck
thanks alot guys im sending the trany out tomorrow to him he told me as soon as he gets mine he will ship out a new one then hell call me back and tell me what happened. i was thinking of having him send a build sheet and im gunna say im gunna have a tranny shop verify all the. because i really don`t think he built it to the specs in the auction. this is what the auction said Meet "Black Maxx" This 700R4 is a High Performance fully Remanufactured Transmission, By a certified GM Builder. This unit is SUPER HARD Hitting and RACE READY. This Unit goes thru a Intense Build Process. What makes BLACK MAXX the Perferred Choice is What you don't SEE ! Our Team has been perfecting the ultimate 700R4 and NOW it's available! We incorporate many of the known Improvments such as the 13 Vane Rotor Assembley in the pump;Hardened Pump Rings; Teflon Pump Bushing; Kevlar Band;Full 500 TV Boost Valve; and lots of Accumalator and Plate Modifications. The ULTIMATE Z-PAC , 14 New Frictions and steels for 3/4 clutches. A Master Rebuild Kit for all needed Soft Parts. Also the BEAST super Strength, super harden, sun shell with a new Cryo-Treated ,hardened sun shell gear .Yes the HIGH PERFORMANCE 29 element sprag. I also Install a Fairbanks "SUPER SERVO" for Super HARD HITTEN 1-2 Shifts and an SUPER FIRM 2-3 Shift. This also Provides Positive 3-2 Kickdown and a Quicker release on 4-3 downshift.This Servo has 35% more Apply Surface Than The Corvette Servo. Also Installed is a Newly Geared Light Sprung/Weighted Governor To hold for a higher shift point at Peak Power band. The Valve Body and Plate Have been Reworked, Drilled and polished to Implement our proprority version a Stage III Shift Kit. Both input and output shafts are hardened along with the 5 pinion roller planetary set. An Extra Deep Pan To Keep "Black Maxx" an Extra 20-50 Degrees Cooler is Standard . This unit has been well Tested in House and has performed for us as high as 900 HP>. It is Now released! The Warranty is a One Year Exchange Warranty as Long as you Install a New Converter ; Proper Cooler System Flush; and Have The Detent Cable adjusted and verified. Needed is a converter match that is for serious performance applications over 500ft.-lbs. of torque.
Old Apr 5, 2004 | 07:03 AM
FireRed91Z28's Avatar
Car: 91 Z28
Engine: currently 350...BUILT 383 soon
Transmission: T56 w/4.10's
hmmm interesting. did you have that specific torque converter?
also is this guy dealing these on ebay? does he have a website?
i will have my T56 installed in about a week depending on New England weather...when my motor build is finished i will be puttin 750RWHP at the least and if i get sick of a 6 speed (which im sure i prob will not) and i want consistant times, or get serios in drag racing then i want an overdrive tranny that will handle my power, preferably a 700R4. i didnt know anyone can build them to those specs till now.
sorry my post isnt much of help but id appreciate your help.
Old Apr 5, 2004 | 07:55 AM
caplt4's Avatar
Engine: 305 EFI
proryder2, if that is true, the tranny should not brake or have hick up, it should handle anything you trow at it, the next one you get, inspect it before you put it in the car, an ask them for a shet stating everything the tranny has been done.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
ericjon262
Sep 11, 2015 06:07 PM
84 TA NV
Sep 6, 2015 08:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
