Gl5 vs GL4 gear oil
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Gl5 vs GL4 gear oil
ok I hear that GL5 gear oil has a problem with eating brass parts is this true? please base it on fact not just what you hear guys also
how long does it take to eat the parts would you say also?
and hwat are the real differences between GL5 vs GL4?
also what is up with some people using ATF in their manual gear box?
whats the point/reason in doing that when I would think gear oil would protect a lot better then ATF
if i really wanted to know or research it i'd get the MSDS for the oil in question. i don't belive there is or could be anything that would eat brass parts and not harm aluminum, steel, or plastic. as for aft gm switched to atf in manuals to increase milage, among other reasons. i use amsoil or m1 gear oil in all my manuals ,reguadless of what gm says with no problems. the truth is most i ever did was 50,000 miles on a 10 year old wct5, it had 80,000 on it when i switched to amsoil.
Car: check
Engine: check
Transmission: check
Re: Gl5 vs GL4 gear oil
The WC T5's (and maybe the T56?) have linings on the inside surface of the synco's. This lining is of the same type as used in automatic transmission clutches. Hence one major reason for ATF usage in a stick tranny.
RBob.
ambainb
Apr 25, 2016 09:21 PM
gixxer92
Sep 1, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
