Lookin into a transmission, Need help and advice on a manual.
Car: 83 Trans Am
Engine: 355 4 bolt main, One day it will run.
ok, im lookin into transmissions. I just dropped my engine in my car, and i have a NWC T5.
I put in a SBC 350, 30 over, with intake, heads, carb, distributer, cam, ignition, etc... Good for atleast 330hp, if not more, and im not done (but who ever is). I also have plans on building a blown 383 (supercharged, not blown up
yet. ) in the next year.
Im not dumb to think my stock tranny is going to hold up to a good launch on slicks, but what will?
I hope to eventualy get an engine in my car around 450-500hp at the crank. I will be running atleast 3.73 rear end, if not higher.
Im currently running my stock 3.73 rear, on street tires.
Now, im not scared of a little fab work, but i would like to keep it to a minimum.
Im realy leaning towards a T-56, but ive seen threads about a certain T-5 thats suposedly stronger. I typicaly browse forums around 2-4 AM, and dont remember half the stuff i read.
Can anyone give me any info about this T5 if you know what im talking about?
Also, what are your opinions on the Tremec T-56 ment for the 3rd gens? Is it worth the money, or is it just as easy to put on a t-56 ment for 4th gens? I know you have to use an adaptor plate, and shorten the drive shaft, and torq arm, and use a diffrent crossmember for both of them, but is the 4th gen transmission casting a real problem, or cause a problem with shifter location, compared to the Tremec 3rd gen t56?
Also, i know that the tremec kit is ment to bolt onto the stock T-5 bell housing, but why cant i use a t-56 bell housing? I think i read something about it using a pull clutch. Does it use the same master cylander? Would it be easy enough to swap out slave cylanders?
If i can use a T-56 bell housing, do i still need to do the rest of the mods, like the cross member, driveshaft, torq arm, etc? And would the shifter still line up? Also, will i need a new clutch ment for the T-56 setup?
I would just rather spend a few bucks on a transmission, to never have to worry about it, or just worry about it alot less.
Thanks. And if all these questions have been awnserd in other threads, point me the way.
yet. ) in the next year. Im not dumb to think my stock tranny is going to hold up to a good launch on slicks, but what will?
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
If you want a manual that is bullet proof and can use the stock thirdgen manual equipment. Get a Tremec TKO 5 spd. Don't have to cut the shifter hole or anything. I wouldn't bother with a beefed up t-5 (G-force makes those). Either get the t-56 if you wanna do a little fab work, or get a tremec tko for a 100% bolt up project.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
