Need help with torque convertor help...ASAP!
Old Apr 3, 2004 | 01:31 PM
supermaxxbasher's Avatar
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
alright I have a 700r4 tranny and I had a cam installed here are the specs of the cam.....Crane cam 272* cam with .454" lift on both sides, and the powerband is 1800-5500....the engine will never see more than 320hp...would this TC be a good choice......
" Street Raptor " Fits 700R4 transmissions (1982-1993). This heavy duty balanced converter has furnace brazed fins and added strength. If you have a problem with your fins coming loose this is the way to go. This converter stalls at 2200 to 2500 RPM and gives a faster launch than a stock converter. Also comes in 1700 and 2000 stall speeds. Rated up to 350 horse power. Cost $165.00
I need to know ASAP cause I need to order one now...
Old Apr 3, 2004 | 03:20 PM
Car: 89 camaro RS
anyone?
Old Apr 3, 2004 | 06:08 PM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
If the cam starts coming on at 1800 (with properly set up engine, headers, exhaust, intake etc. ), I'd go for the 1700 to 2000 stall speed provided I had a 3:23 or numericaly higher geared rear end.
If I had a 2:73 gear in the rear end, I would choose the 2200 to 2500.
These are my choices with my type of driving (weekends only,... its a toy), you will have to figure out how you will be driving the car and go from there. If its going to be a daily driver I would go for the 1700 to 2000 no matter what gear the car had.
Old Apr 3, 2004 | 06:23 PM
Car: 89 camaro RS
opps I forgot the car has long tube headers, full true dual exhaust and intake which its carbed..the car has 3.42 gears in it as well...so I should go with the less stall....this will be in my daily driver as well...
Old Apr 4, 2004 | 01:12 PM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
If it was my car for daily driving I would go with the lesser stall. Like 500rpm over stock. "Saturday Night Special" is what they called them when I was in high school, don't know if that is still the current lingo.
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
