Who has rebuilt there posi ???
Subscribe
Apr 5, 2004 | 11:41 AM
My posi is dead and i want to rebuild if i can.I'd like
to know how hard it is,and how much the parts run.
Thanks to all !!!! :rockon:
Reply 0
Apr 6, 2004 | 08:18 AM
9 or 10 bolt posi?
Ed
Reply 0
Apr 6, 2004 | 09:19 AM
i have the same question, mine is a 10 bolt disk brakes
you can't rebuild a 9 bolt posi can you?
Reply 0
Apr 6, 2004 | 09:30 AM
You'd probably spend more money on parts to rebuild the posi than to buy the $100 take off unit from SLP.
Reply 0
Apr 6, 2004 | 10:20 AM
For 10 bolts, I'd go with the torsen from SLP, no clutches to wear out and they swap right in. For $100 or so, you can't go wrong.
You can rebuild 9 bolt posis, and a good fix is to shim them a bit tighter and clean up the cones. Larry Burd has shims if anyone needs them. It's not easy so to speak, so you've been warned.
Ed
Reply 0
Apr 6, 2004 | 05:33 PM
I've searczed slp site today and the $99 posi is no longer listed there
What about some rebuild kit? how much are they?
Reply 0
Apr 6, 2004 | 08:46 PM
I have a stock 10 bolt rear.I miss the SLP take off by
2 posi units.That sucks,But thats life.
Thanks T o All :rockon:
Reply 0
Subscribe
