9 Bolt posi with 3.27
Old Apr 6, 2004 | 09:40 PM
86TAtony's Avatar
Car: 1986 Trans Am
Engine: LG4 305
Hi everyone, I am going to buy a 9 bolt posi with 3.27 gears for $150. It has about 100,000 miles on it and it came out of an 89 formula with a 350 TPI. I was just wondering if this a good deal?
Any input is appreciated,
Tony
Old Apr 7, 2004 | 06:50 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Not bad,better if it has disc.even better of they are the aluminum caliper type.Just make sure the posi & the axles are in good shape.
Old Apr 8, 2004 | 12:03 AM
86TAtony's Avatar
Car: 1986 Trans Am
Engine: LG4 305
Yea the axles are in good shape, I did a hub runout test on both sides and they were about .001 from being perfectly fine. It was mostly from just rust that I couldn't get off with the metal brush too. Posi is in good shape also. It does have disc also! Thanks for the info
Tony
Old Apr 8, 2004 | 01:42 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
both wheels the same way doesnt necesarily imply its still good. IIRC, if the torque is less then 35 ft-lbs to rotate one of the wheels with the other locked and the trans in park, the posi is dead. Id be willing to bet with a 100k on the clock its about time for new axle bearings and a new set of clutch cones anyway. There is some more info on the 9-bolt at diffsolutions.com
Old Apr 8, 2004 | 07:14 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
I just drove 4 hours to pickup a 9 bolt just like this one and we had agreed on 150 bucks but the guy let me have it for 100. I still say 150 is a good deal considering how much junk yards would charge you if they even have one.
Old Apr 8, 2004 | 07:28 PM
Car: 88 Camaro SC
Engine: SFI'd 350
100-150 is a great price for one of the ones with a higher series carrier. I paid 250 here in hell for one with a low series carier + 28 spline axles, complete pbr brakes, lines, + 'FY' master cyl (forgot to take the master cyl like an idiot, though).
Old Apr 8, 2004 | 08:45 PM
Eightyninef's Avatar
read the many post / articles on this board about rebuilding the posi unit. much easier while the rear is out.
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
carattini
Sep 10, 2015 07:46 AM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
