700r4 to TH350 swap HELP NEEDED
Old Apr 7, 2004 | 08:18 PM
johnybravo129's Avatar
Car: 1985 Camaro
Engine: 350 ci 4 bolt main .30 over forged fed mogul pistons
I'm sure this has been discussed many a time but just help me... I'm swapping the whole drivetrain in my car... I"m going from v6/ auto (2004r er whatever) to v8/th350. Here are my questions...
1.) Will my existing driveshaft work?
2.) Will my existing crossmember work?
3.) What mods will I need to do and how is the fit?
I was initially going to do a t5 swap... I have the trans and everything but i decided that a th350 would be better for power so... thats what im doing! Thanks in advance for any help!!!
Old Apr 7, 2004 | 08:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
1) No, it's too short (unless the TH350 is a 9" tailshaft version).
2) No, it's too short (needs to be moved forward, and since the frame rails aren't parallel, the crossmember needs to get longer as it goes forward).
3) Torque arm mount. Spohn can take care of all of this for you. The fit is fine.
Old Apr 8, 2004 | 09:45 PM
Cam84358's Avatar
Car: 84 Camaro
Engine: v6 to v8 swap 357ci chevy
Transmission: TCI Turbo 350
Ditto. B&M and Hurst sell a changeover kit.I used the B&M kit ,had a machine shop fabricate a driveshaft [ 3 inch longer for 6 inch tailshaft 350].Also used the B&M megashifter.
camaro11j
Sep 19, 2018 08:49 AM
IROCZ1989
Jan 24, 2016 03:55 PM
TreDeClaw
Aug 14, 2015 06:58 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
