700R4 whines above 3000 rpms??
Old Apr 12, 2004 | 06:41 PM
305IrocZ28's Avatar
Car: 1990 IROC-Z
Transmission: 700-R4
I only noticed this recently- its most prominent when the car is cold (in the mornings usually, however it also happens if its been sitting for a long time mid-day). Shifting from Park into Reverse usually is accompanied by an almost bad-power-steering-motor-like whine, just more raspy then anything else (no "tone" to it...just a raspy sound). Also, in first and second gear (and third, although I haven't had it up this high too many times) at around 3000 rpms it makes the same kind of whine. However it doesn't make this whine when shifting from Park to Drive (under the same conditions). It sounds like it is coming from the front of the trans....TC perhaps? HELP!
Old Apr 13, 2004 | 03:23 AM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Do check the level and condition of fluid of course...but it sounds like the front pump is failing.
Hotrodboba400
Dec 10, 2019 07:07 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
