Removing plate from tranny mount
Old Apr 17, 2004 | 12:37 AM
GoonieZ28's Avatar
Car: 91 Z28
Engine: 5.7 TPI
Transmission: ProBuilt 700-R4 & Vigilante Torque Converter
So after having my ES polyeurethane tranny mount put on, I started to get a strong vibration while going above 80. I read here that it's because it should be installed without the plate that came with it. Well I crawled under the car today and noticed there are two thin metal plates stacked on top of each other, which both go above the tranny mount. Do I just remove one, or both? Any one think this is a good idea?
Thanks!
Old Apr 17, 2004 | 01:37 AM
carfixxer's Avatar
Car: 87 GN & 87 T
Engine: 3.8 V6
Transmission: 200r4
On the ES instructions it in big bold type the plate is to put preload on the mount. I tink if you take it out it will be too soft anfd you will put alot of stress on the bellhousing and may crack it. (see thread bad trans mount)
Eric-86sc
Apr 3, 2016 03:52 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
