Manual Transmission Fluid
Old Apr 18, 2004 | 12:51 PM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
Does anyone know what exact type of fluid the manual tranny in my 1987 2.8 takes? and how much?
Old Apr 18, 2004 | 01:04 PM
MdFormula350's Avatar
https://www.thirdgen.org/techbb2/sho...t=manual+fluid
https://www.thirdgen.org/techbb2/sho...ht=t5%2A+fluid
84 Z28 5.0 HO's Avatar
Car: 84 Camaro Z28
Engine: 305 L69
It takes regular ATF 3, If you put gear oil in it, the gears will be hard to engage and the trans will wear out quicker. Open the fill plug and fill until fluid comes out. I think it's about 2.5-3.0 qt. But thats not 100%
Old Apr 18, 2004 | 02:14 PM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
thanx loads... lol, i figured it would be quicker and easier just to ask than to find out on my own.. thanx a lot
Old Apr 18, 2004 | 06:02 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
wc t5 takes ATF
non WC takes gear oil
different synchro pads (or whatever they are called)
Old Apr 19, 2004 | 04:28 AM
ede's Avatar
ede
i've run amsoil gear oil in wct5 with no problems. went from around 80,000 miles to 135,000. it might of been ready to break but never did. no problems with shifting or anything else.
Old Apr 19, 2004 | 08:15 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Ive also used gear oil in my "2nd gen wcT5" with no problems.
As of now I'm using syncromesh and cold shifts are a tad easyer.
I'd reccomend all T5's that require ATF to be switched over to full synthetic GM Syncromesh, its a much better fluid then any ATF, service intervals will be decreased and transmission life will increase.........usually.....................
jhawkeye
May 25, 2022 06:33 PM
bjpotter
Jan 22, 2019 12:27 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
topher107@
Aug 28, 2015 10:47 AM
