torque specs
Car: Z28
Engine: 310
torque specs
I noticed there was a small leak around my transmission pan so I changed the gasket. I must have over tightened it and smashed the gasket because now the fuild pours out. Is there any certain specs I need to torque it too?
Thanks,
Joe
Thanks,
Joe
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Make sure to clean both surfaces very well and ensure there is no oil on them (use some brake cleaner on a paper towel)... Then put it together with just a gasket (no sealer, and the rubber gaskets work best if you do the prep right). Then torque to 12 ft lbs (seems small, but overtightening can squeeze the gasket out)...
no green
Jan 9, 2016 09:22 PM
