how much gear noise does a T5 make?
Old Apr 17, 2004 | 08:45 PM
cochev's Avatar
Car: 86 z28
Engine: 305 Carbed
Hey, just bought my first 3rd gen. its an 86 with a305 and t5. it seems to have a fair amount of gear noise in the first 3 gears. is this normal or a sign of wear? the car only has 116k and looks to have had a pretty easy life. i'm a truck guy and the 4 speeds i've owned have all made some noise, but not familiar with cars at all. thanks,
jason
Old Apr 17, 2004 | 09:26 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
I had a 15th Ann. T/A with a WC T-5 and it was fairly quiet.
Old Apr 17, 2004 | 09:52 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
yea Ive got a 86 gearbox in my car with about 100k on it and its quiet, check your fluid and make sure its auto tranny fluid and not gear oil and its the right level.
*edit* nice car btw, looks very cherry.
Old Apr 17, 2004 | 10:33 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
If all is well inside the trans, it should be quiet when running.
The noise you are hearing is most likely the bearings on the countergear shaft. It won't get any better, and depending on how it's maintained and driven, could still give many miles of service.
Old Apr 18, 2004 | 08:05 AM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
Mine will "whine" in 1st gear but that is about it.
Old Apr 19, 2004 | 12:42 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
my t-5 is pretty much silent
Old Apr 19, 2004 | 01:52 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
My WC T-5 was silent until I put a hurst billet shifter in it. Now it makes a little noise but only through the shifter and it is not that loud.
Old Apr 19, 2004 | 07:15 PM
cochev's Avatar
Car: 86 z28
Engine: 305 Carbed
i checked the fluid and its full and has atf in it. its noisiest during coast or deceleration. also makes some noise with the clutch ingaged in nuetral and goes away when i puch the pedel in- so i'm thinking my through out bearing might be part of the problem too.
Old Apr 20, 2004 | 12:16 AM
When you push the pedal down, the guts of the transmission will stop turning after a few or five seconds; nothing is going to make the noise when it's not rotating.
RedLeader289
May 28, 2019 01:47 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
Bigold4x4
Sep 28, 2015 05:21 PM
mfp189
Sep 27, 2015 09:25 AM
6998poncho
Sep 25, 2015 02:56 PM
