Whats the best lockup kit?
Old Apr 20, 2004 | 09:37 AM
70BuickSleeper's Avatar
Car: 84 Z28
Engine: 305 HO
What is the best lockup kit for the trans? B&M, Painless, or TCI ?? I just want it to lockup at highway speeds and behave normal. Thanks
Old Apr 20, 2004 | 10:24 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I used the TCI kit 15 months ago when I added one to my 454HO Commander 950 MPFI 1986 Suburban, and it worked fine. That kit also came with a vacuum sensor that should disable the TCC when accelerating heavily, which was handy.
I still thought it was locking up too often at low speeds, like while driving around in town. So I just wired in a toggle switch between the power feed to the tranny. If you're running a 700R4 (as opposed to an electronic tranny), the power is only used for the TCC lockup and you can just cut the power feed to the tranny to keep it from locking up when you don't want it to (like while in town). I just enabled mine when I was on the highway, even used a lighted toggle switch so I could tell at a glance if it was on or not.
Hope this helps, good luck with your project!
- Vern
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
customblackbird
Oct 1, 2015 04:30 PM
1Aauto
Sponsored Vendors
Sep 22, 2015 03:39 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
